Tire Pressure sensor
Old May 25, 2011 | 10:56 AM
Hawk Monster's Avatar
Default Re: Tire Pressure sensor
The reason to replace all 4 senors is simple. They fail about the same time. Do the job once and that way you will not drive for a week, month, etc. and have to do it again. Sometimes it is easier to replace parts when you already have things a part. I guess you paid for an hours worth of labor even if the job took 15 minutes. I surmise you could do all 4 for that hour of labor and the only additional cost is the parts.. You will be back if you only change one.
Old May 25, 2011 | 11:09 AM
waldig's Avatar
Talking Re: Tire Pressure sensor
I dont like them, I dont want them, I dont need them, So I did the simple delete of them. Running different pressures / tires / slicks eliiminated the benefits of them so THe delete worked for me and I have never looked back. They are excessive weight and cost that I feel are of no benefit, my two scents. Woody
BTW your not removing demounting remounting and balancing and installing 4 wheels in an hour.........
Old May 25, 2011 | 11:11 AM
05roadsterguy's Avatar
Since I check My Air water and Oil every time I fuel up the Malfunctioning TPMS was of no conseqence to Me I Just Disabled It.
After all I survived the first 30 Years of My motoring life with out this particular Idiot Light.
MikeR's Avatar
While I agree with you completely and will do that same thing... the shop/dealer should be telling him which sensor is bad....not that they all need to be replaced...(unless they all go bad at the same time... )
Old May 25, 2011 | 12:00 PM
jcprovost2's Avatar
I will search for other tire shops in my area. No Americas/discount tire shops in MS. Dealer want over $500 for the 4 sensors.
Originally Posted by MikeR
the dealer probably wants more of his money....
the EZ sensors are $60 each at Americas/Discount Tires.... plus labor of course..I would just wait till I replace the tires if mine went bad... as my car is now 6 years old I will probably put in new sensors when I change the tires again, BEFORE they go dead....
Old May 25, 2011 | 12:57 PM
It would almost be cheaper to buy new tires !!!!
Kodebuster
Nov 5, 2020 04:06 PM
Danyuhl
Nov 2, 2019 05:18 PM
velociabstract
16
Oct 12, 2015 10:56 PM
Bifftws
Racing
Jul 28, 2015 05:31 PM
axnguyen
Jul 21, 2015 11:41 AM
