Originally Posted by ImportLabSRT
350whp may be a little high for an Evo8 16g with a stock 6-bolt engine. The 6-bolt has a low 7.5:1 compression pistons and the Evo8's are 8.8:1. But, that means you can run more boost with lower compression..... plus the if its an early 6-bolt it has the larger rods too.
Bryan
Yeah it is a big rod 6 bolt, 7.8:1 CR. I was also considering a lower drivetrain loss into my guesstimation. Plus I have a waste gate dump, 3 inch exhaust, and two forms of intercooling(FMIC and Water/meth). Oh yeah, I also have balance shafts eliminated and only running water pump and alternator. It's going to be loud when the waste gate opens. I think the record for the big 16g is over 450AWHP now.
