Re: ***** Deep
where did you put the high pressure safety release valve in the rail? it looks like you just removed it. i would add it back in
I was under the impression that was a pulse damper. A diaphram with a spring behind it. I attached a guage to the old connection. The guage vibrates at idle but smooths out to 55psi right above idle. This was a spare I can always put it back to stock.
