Old Jun 15, 2011 | 05:22 PM
LugNut's Avatar
LugNut
Smile Rearview / Backup Camera Installation Hints and Pictures
Well, I've finally, and successfully, installed mine! Thanks to all who posted comments on such -- there were many valuable tidbits. Here's some of my experiences, if you attempt similar to address the massive blind spot. If you can't view the pics here, go to my gallery:
I bought a new/sealed large-screen, wireless PEAK SafetyView PKC0RC, via eBay, for US$58 including shipping a little over a year ago. It has a seven inch color LCD screen, and can accept other AV inputs.
From readings I knew to tap into the right-rear wiring. Removing the right sail panel was necessary to get the rear center interior trim out, and it then gave me good access for installing the transmitter up high (later pic).
Here's the back side of the right-rear sail panel. It was a pain to remove, and install. The trim around the right seat belt must be removed first, as well as the cargo area's carpet and lower-right carpeted wall. Then it is ripped out with much more force than I would have liked to use, for a plastic piece. Reinstalling it was a pain too, and required that I climb into the cargo area (keeping my weight on the front metal pan, not the styrofoam to the rear.
Here's the rear "transom", after the center trim was out. Note the little hand holes down low, especially to the left-of-picture-center -- they helped me feed the camera wire.
I didn't want any exposed wires, wanted the camera to be mounted in the center, and hoped not to drill any holes for the camera-to-transmitter wire. Well ... things snow-balled, and I ended up pulling the rear fascia, which really wasn't that difficult -- see someone else's the thread on "rear bumper cover", I posted some hints and pics to it too:
Note in the pic above the four little black, round plugs -- success in finding a way in without drilling a hole! Then threaded up to one of three existing holes in the rear sheet metal, behind the rear "transom" (what's that sheet metal area really called?).
Here's the transmitter installed -- it's heavy-duty double-sided taped up high and forward to help get a stronger signal to the monitor. I spliced the transmitter's power leads into the right on-taillight's harness (_not_ the body's harness). Brown was +12V, and black was ground. Note that the brown wire in the body's harness in _not_ +12V. I soldered and taped the connections to reduce future connection problems -- I do not want to pull that trim again -- what a pain!
Tested the unit before buttoning back up the car.
Here's the camera installed. I have an aftermarket chrome license-plate trim ring, and it worked nicely for pointing the camera downward a bit. I snaked the lead between the trim ring and the plate, so no wires are visible outside. As another member mentioned, the camera is very close to the hatch's release, but mine fortunately clears it. Also, a good hint from another was to seal the wire's entrance to the camera to help keep water out -- I used "Shoe Goo", both just before and then after mounting the camera (the wire gets bent during installation).
I planned to mount the monitor on the right-side dash, using one of those custom Panavise brackets (now for sale ... inquire {6/30/11: likely sold}), but the large screen made it stick out into the passenger's space (a safety problem), and I didn't like how it or the wires would look. So ... I mounted it between the seats, where I normally turn to look anyway! If you have a really stiff neck, this location isn't for you. But for me, it works, and looks great!
I made a custom mount, out of wood, and painted it black. The monitor is strapped to it, using the supplied straps, and the bracket it then held in place using the never-used umbrella clips (must remove one to put in the bracket -- easy). The power wire then goes down behind the driver's seat, to the console, then, for now, to the cigarette lighter.
Above shows an actual image too.
I was pleased to see that the unit turns off completely when the key is out -- the cigarette lighter apparently shuts off. I don't like the monitor's cigarette adapter plug and exposed power wire, so I will be hard-wiring it when I yank the console here shortly to replace one piece of trim that has the peeling black plastic covering.
Looking forward (backward?) to actually using the camera in a parking lot soon! And I hope these pics and hints help others, or maybe show that it's a _lot_ of work to do a pro-type installation.
