Old Jun 18, 2011 | 03:09 PM
  #859 (permalink)
ckovach's Avatar
ckovach
Default Re: *Needed* 20 to Pre-order Wavetrac LSD for SLK32/SRT-6
Originally Posted by 32krazy!
ok if i understand this correctly the spacer and clip for the bolt in axles on the slk32 isnt working properly. i now have a 2003 slk32 and the axles are the same as the xfire(push in axles) the newer axles should work fine in place of a older bolt in axle but dont know the pricing
btw jim it isnt the c32. that is a different differential altogether
I believe the early style axle is on '32 VIN numbers thru F257904 and the later style is from F257905 forward. But just to confirm, Steve, is the later style factory '32 setup on my '03 the same as the SRT-6 (so no spacer and C-clip mod...)?
