Originally Posted by amx1397
One more piece of the puzzle;;;;;;;;;;;;;;;;; slk32 people ,,, #1 i hope you are going to send your diff to Devin for him to install the Wavetrac,, and below is why.
Here is the newest news on the slk 32Wwavetrac
you need to send your diff and the two stub axle shafts to Devin ,,,because he needs to machine the grove at the end of the axle about ,011 ,,,( this does not hurt a thing) it just allows the spring clip to go on and let the axle shaft (stub) slide in and out, like the one peace axle,,,;now the good part the .011 that is machined ou,t does not hurt the C-clip at al,, in other words if you want to put the stock carrier back into the car to sell the car or Wavetrac it will fit just like before. there will be no extra charge for the machining. this could also include the 2004 crossfire,people that want a Wavetrac, jim
of course if you sell the wacetrac, you might want to swap axles with the buyer so his new wavetrac and axles fit .
i have been in contact with devin on the axle issue for the early slk32 and think i found him a couple axles to test the new fix on . i should hear from him on monday if it works. remember this only affects the axles that are a 2 piece design
my diff arrived in cali today and hopefully will be shipped back early next week with the new wavetrac installed!
