Originally Posted by 32krazy!
i have been in contact with devin on the axle issue for the early slk32 and think i found him a couple axles to test the new fix on . i should hear from him on monday if it works. remember this only affects the axles that are a 2 piece design
my diff arrived in cali today and hopefully will be shipped back early next week with the new wavetrac installed!
Steve, if i remember correctly you sent your stub shafts with your diff. yes?
also if anyone has a set of axles stub shafts for the machining testing that would be great Devin needs them once everything is worked out they would be returned. thanks in advance.. thanks Steve. jim
