Re: Fuel Filter
You can find the Mahle fuel filter, which is most likely another source for the factory OEM unit, for 15-20% less than the Mann filter. Just do a search for the Chrysler Crossfire Fuel Filter and quite a few websites pop up that list both versions. The Mann will be $55-$60; the Mahle will be $40-48. Both are typically stocked.
And if you look around in eBay, per the link above, you'll find quite a few sources of fuel filters at even lower costs. Sticking to a Mann or Mahle in this application is probably not necessary. Just about anyone's filter will work. Heck - most are made by only a couple of suppliers and then labeled with someone else's part number.
Later,
