Old Jul 9, 2011 | 10:26 AM
ctsemicon's Avatar
ctsemicon
Default Re: Suspension problem
I suggest that you might have tightened the lower control arms while you had car jacked up - this can cause control arm to hang up in wrong position. the front and trailing lower control arm bolts should receive final tightening once the car is lowered completly to the ground so that compression on the bushings is set at normal wheel position (not the jacked-up position). Just a thought......regards and good luck.
