installed my diff today, not an easy job!! some fun facts you diy guys will need
!. rear diff bolts torque 84 ft/lbs
2. front diff bolt torque 33 ft/lbs
3. all suspension bolts 52 ft/lbs
4. driveshaft bolts 44 ft/lbs
the diff hates to be on a jack flops everyway and its heavy!! find a friend to help staedy the diff to install the 2 axles. now if the front diff bolt wont tighten theres a nut inside the frame channel that needs a wrench. simply dislocate your shoulder turn your hand upside down and hold the wrench at an insane angle to get a tiny piece of it on the nut!
other than that its a piece of cake!
