Old Jul 9, 2011 | 08:14 PM
  #962 (permalink)
Bigkid's Avatar
Bigkid
Default Re: *Needed* 20 to Pre-order Wavetrac LSD for SLK32/SRT-6
Originally Posted by 32krazy!
installed my diff today, not an easy job!! some fun facts you diy guys will need
!. rear diff bolts torque 84 ft/lbs
2. front diff bolt torque 33 ft/lbs
3. all suspension bolts 52 ft/lbs
4. driveshaft bolts 44 ft/lbs
the diff hates to be on a jack flops everyway and its heavy!! find a friend to help staedy the diff to install the 2 axles. now if the front diff bolt wont tighten theres a nut inside the frame channel that needs a wrench. simply dislocate your shoulder turn your hand upside down and hold the wrench at an insane angle to get a tiny piece of it on the nut! other than that its a piece of cake!
Thanks for the info Steve.
