Originally Posted by 32krazy!
seems like a lot of work bryan. remove the track bar bolt the rear lower control arm bolt and the lateral arm bolt all from the frame positions and the diff will move enogh to pop the axles out. no need to remove brakes or anything else. jonnyb did an excellant writeup which is what i used to remove mine. 12 bolts total removed 3 drive sahft , 3 diff mounts 6 suspension
Probably didnt need to take the brakes off but its only a total of 4 bolts. I am doing camber arms anyhow so that step didnt bother me. But Jonny's write-up would probably work very well as you stated.
