Old Jul 17, 2011 | 07:52 AM
JHM2K's Avatar
JHM2K
Default Re: cut srt6 springs and fender height
Originally Posted by velociabstract
I cut 3/4 coil off the front and 1 coil off the back. I had to use a dot 5 on the front or I'd get some rubbing. My front setup was 235/40/18 with a 10mm spacer. On the rear I was having interference with the sway bar and aftermarket adjustable camber arms (only at the track at ridiculous speeds) so I had to go with a dot 4 pad which is the tallest they make for the rear. I believe you can get the 25" to 25 1/2" cutting 1/2 on the front and 3/4 on the rear with the stock spring pads. You'll most likely have to do some adjusting with the spring pads no matter what. It seems not all cars lower the exact same amount. If you search you'll find springs cut much more than mine were without rubbing but my experience was different. (I'm now on K&W's) Don't let the coils get too hot while cutting them. (use lube to keep the temps down)
Les
When I bought mine from Shelton, he said he had removed a full coil from each spring. I'll have to go out and measure my height, but it's just at the verge of rubbing. Big bumps at speed case the tires to kiss the fender liners if I'm not careful. But at low speeds, and in the parking lots, no drama and no rubbing, even on lock-to-lock steering.
