Old Jul 21, 2011 | 10:42 AM
robby363's Avatar
robby363
Default Re: Relay Replacement In RCM
Originally Posted by SILVERBULLET
I Have Read All The Treads On Rcm Fix, I Tried Them And Still No Help. I Also Changed The Batteries In The Key Fob, Now The Car Cranks More Often But Cuts Off In 4 Seconds. I Can Get The Car To Crank With The Key I Haven't Changed The Battery In And It Will Run Longer And Then Cut Off. What Am I Doing Wrong? Is This Rcm Covered Under The 8/80 Warranty? Please Help, I Want To Drive This Baby.
Have you tried to reprogram the key fob? It sounds like you have a problem in the security system that's not reading the security code. If the car starts and stalls out a few seconds after it's most likely the security system.
