Relay Replacement In RCM
Old Jul 8, 2019 | 05:23 PM
  #61 (permalink)
Netwizz's Avatar
Default Re: Relay Replacement In RCM
This part conforms to an industry standard, in all necessary ways, it has the European pin layout. Their are numerous companies competing in this are so it is not a rare item at all. It may take a bit of digging to find it snd it may have to be purchased in a higher quantity than required.
The extras can be sold easily on this forum, I purchased mine from Pizzaguy some years back.
I thought that was the case, however I've failed so
far to find a European supplier.
Old Jul 9, 2019 | 02:57 AM
  #62 (permalink)
Netwizz's Avatar
I'm still unable to locate a European supplier of these relays. Will spend some time today online again!
Old Jul 17, 2019 | 03:15 PM
  #63 (permalink)
Netwizz's Avatar
Hi All
I have now managed to source some of these relays in Europe!
I have successfully replaced mine and the Crossfire is running sweetly again!
If anyone in Europe has a similar issue I can supply a relay at cost as I have 10 in stock.
I could also do the repair for you if you cannot, again at cost, just PM me to arrange.
Netwizz
Old Jul 17, 2019 | 05:13 PM
  #64 (permalink)
Originally Posted by Netwizz
Hi All
Netwizz
Good for you, persistence pays.
Old Nov 6, 2019 | 07:23 PM
  #65 (permalink)
mattyremf's Avatar
Hi All
Netwizz
@Netwizz do you still have any of the RCM relays for grabs? or at least where you sourced them in Europe?
Old Feb 16, 2020 | 03:55 PM
  #66 (permalink)
Cotyt94's Avatar
I just came across this PDF of RCM Repair. ... Enlighten me guys please! Is this my RCM?
Old Feb 16, 2020 | 04:00 PM
  #67 (permalink)
That is not the RCM.
Old Feb 16, 2020 | 04:09 PM
  #68 (permalink)
No. The RCM is the module farthest away from the battery with all the fuses on top.
Old Feb 16, 2020 | 04:10 PM
  #69 (permalink)
Cotyt94's Avatar
How do i get the wire plugs off of the top of the actual RCM?
Old Feb 16, 2020 | 04:13 PM
  #70 (permalink)
Are you trolling us?
You managed to get the ECM out (which is no simple feat, that damn connector lock thingy was designed by some ******* German engineer with the goal of making AMericans look stupid) but you cant unplug the connectors from the damn RCM?
Ya gotta be kidding me.
Old Feb 16, 2020 | 04:19 PM
  #71 (permalink)
Cotyt94's Avatar
na dude i feel like a toolbox myself. I told you im not good with wires. The other two modules look easier to me idk. Those wire plugs on top of the RCM just look fragile.
so anyway they just.... Pop off?
oh boy i think i see the hole for the pick now 😭
Old Feb 16, 2020 | 04:27 PM
  #72 (permalink)
Hole for a PICK !!!!! ?????
Please don't. All you do is lift the RCM out, then unplug each connector one at a time by grasping the plug, NOT the wires.
Old Feb 16, 2020 | 04:31 PM
  #73 (permalink)
Cotyt94's Avatar
Yea that little hole on top i just gently wiggled them off with my pick
Old Feb 16, 2020 | 04:35 PM
  #74 (permalink)
Not a bad idea, really. I usually use a flat blade screwdriver to pry them up -as George said, just DO NOT yank by the wires.
I can't believe you managed to get the damn ECM out without asking for help. I HATE that bastard connector. You are obviously one who can handle the complicated stuff, but you overthink the simple stuff.
(I do like the pick idea....)
Old Feb 16, 2020 | 04:36 PM
  #75 (permalink)
Cotyt94's Avatar
As i sit here and wrestle with this stupid RCM im baffled how you think the other ones are harder 😂
I also have a bloody thumb from the effer
looks great inside... Bummer
Old Aug 7, 2021 | 08:20 AM
  #76 (permalink)
shortspoon's Avatar
Netwizz
Can you let me know the name of the supplier in Europe for the RCM relays please.
Shortspoon
Old Aug 7, 2021 | 09:04 AM
  #77 (permalink)
Doc78's Avatar
Shortspoon,
It doesn't look like Netwizz has been on the forum since March. You may be able to PM him to get a response. To check to see someones last activity you left click on their name and view their public profile. It will tell you in the upper left corner right under their name their last log on date.
KDW4Him
18
Sep 1, 2021 05:47 PM
Adrian_X
Apr 8, 2020 02:36 PM
northwest_crossfire
May 30, 2016 05:19 PM
oldvintagedude
Aug 14, 2015 06:20 AM
BrenLW
Aug 5, 2015 04:53 AM
