Old Jul 23, 2011 | 11:01 AM
oledoc2u
Default Re: Relay Replacement In RCM
I wouldn't think this is a fuel pump problem. Did you recheck your solder joints? Seems it heated up, and the problem came back. Were the relays OK? Fuel pump problems usually start with a lot of cranking before it will start. If it idled rough after starting, I would look at the crankshaft position sensor. Good luck..
