Old Oct 5, 2005 | 01:09 PM
HDDP's Avatar
HDDP
Default Re: Throttle Response Is Slow!!
This might answer your question regarding the slow throttle response as quoted from the repair manual.
"The PCM recognizes how the accelerator pedal is being pressed and switches between a few characteristic curves. Eighty percent of the engines power is achieved for a pedal travel of about 50% for an aggressive driver and about 40% for a conservative driver. There is no further difference felt above a pedal travel of 90%.
The characteristic curve for a conservative driver is active after a long drive. Then the accelerator pedal must be pressed down unusually hard to obtain a higher acceleration level."
Try the reset I described in my earlier post. I usually perform that operation every time I get into the car. Seems to work well for me! Good Luck.
