Old Jul 29, 2011 | 11:53 AM
onehundred80
Default Re: serpentine belt replacement
Originally Posted by fyrepower
Had the classic oil filter leak so I need to replace the serpentine belt on my 06 XFire LTD. It looks like the 06 belt tensioner is different then the 04. Can any one tell me how I rotate it to install the new belt.
Thanks
The belt tensioner is the same on all models according to the parts lists, #05096525AA. Mercedes part number A112 200 09 70.
The SRT6 tensioner is different though, part number A112 200 07 70
The 17mm hexagonal boss and the locking pin hole are not seen from the top.
The hexagonal boss can be seen in a mirror.
The SRT6 uses the Torx head for tension relief. Use the correct size to prevent stripping it.
A photo by Janes1549
Pin ( 3/16") is shown in the hole used to lock the tensioner in position to keep the belt tension free for service.
Another photo by James 1549. Do NOT use this Torx screw to relieve the belt tension.
17mm socket on the boss on the tensioner casting.
