serpentine belt replacement
Old Jan 27, 2018 | 11:27 AM
  #61 (permalink)
mariontr's Avatar
Default Re: serpentine belt replacement
Well installation of the belt pulley tensioner went fine. What I found easier and as mentioned is if you put the serpentine belt on first from the alternator makes it easier . So started and all seems fine except now I notice some smoke from the driver's side header car being sitting for a week so I'm hoping that I don't have to replace the header gasket . When replacing do you do both sides or just the one with the problem?
Old Jan 27, 2018 | 11:31 AM
  #62 (permalink)
Most likely it is oil leaking from the valve cover vent covers, those are sealed at the factory to the valve cover with RTV sealant.
Do both sides.
You will need to remove them, clean the old RTV real good ( making sure to not let any get into the engine ), then reseal with a small bead of black RTV all around.
Be very careful with the small aluminum cap screws !!!!
Old Jan 28, 2018 | 06:56 AM
  #63 (permalink)
Do both sides.
And the small aluminum screws are intended to be a 1x use only. You should replace these screws when re-assembling the crankcase breather covers to the valve covers. Here's a post that gives you the torque values for the screws when tightening: CLICK. Just slightly over "finger-tight" is a good reference if you don't have a torque wrench. Maybe a 1/8 turn past "finger-tight".
xfClifford
Mar 3, 2021 04:52 PM
Adrian_X
Apr 8, 2020 02:36 PM
sittininthesun
Aug 24, 2015 10:47 AM
UNDER PSI
Aug 1, 2015 02:11 AM
Tp'sfury
Jul 17, 2015 01:15 PM
