Old Jan 28, 2018 | 06:56 AM
  #63 (permalink)
dedwards0323
Default Re: serpentine belt replacement
Most likely it is oil leaking from the valve cover vent covers, those are sealed at the factory to the valve cover with RTV sealant.
Do both sides.
You will need to remove them, clean the old RTV real good ( making sure to not let any get into the engine ), then reseal with a small bead of black RTV all around.
Be very careful with the small aluminum cap screws !!!!
And the small aluminum screws are intended to be a 1x use only. You should replace these screws when re-assembling the crankcase breather covers to the valve covers. Here's a post that gives you the torque values for the screws when tightening: CLICK. Just slightly over "finger-tight" is a good reference if you don't have a torque wrench. Maybe a 1/8 turn past "finger-tight".
