Originally Posted by fyrepower
Had the classic oil filter leak so I need to replace the serpentine belt on my 06 XFire LTD. It looks like the 06 belt tensioner is different then the 04. Can any one tell me how I rotate it to install the new belt.
Thanks
pull handle and a 17mm socket. You attach to the 17mm extrusion which is just below and to the left of the pulley as viewed from the front. Rotate counterclockwise.
( If you want to make it REAL easy - remove the fan : 2 clips at the top and unplug the wire - pulls right out when you finagle the hoses somewhat. )
