Old Jul 29, 2011 | 01:00 PM
fyrepower's Avatar
fyrepower
Default Re: serpentine belt replacement
Originally Posted by alaxfire
pull handle and a 17mm socket. You attach to the 17mm extrusion which is just below and to the left of the pulley as viewed from the front. Rotate counterclockwise.
( If you want to make it REAL easy - remove the fan : 2 clips at the top and unplug the wire - pulls right out when you finagle the hoses somewhat. )
Thanks, I'll give it a try tomorrow morning
