Old Jul 30, 2011 | 03:16 PM
fyrepower's Avatar
fyrepower
Default Re: serpentine belt replacement
Originally Posted by alaxfire
pull handle and a 17mm socket. You attach to the 17mm extrusion which is just below and to the left of the pulley as viewed from the front. Rotate counterclockwise.
( If you want to make it REAL easy - remove the fan : 2 clips at the top and unplug the wire - pulls right out when you finagle the hoses somewhat. )
Success!!!!!
I was able to get the new belt on and I also cleaned up the engine oil. Most of it was on the s plastic pan under the engine.
By removing the fan it made the job a lot easier.
