Old Aug 5, 2011 | 09:58 AM
Kodebuster's Avatar
Kodebuster
Default Re: Winshield washer fluid
Originally Posted by MRGR3YXF
Went and got oil change and they attempted to fill my windshield washer fluid up and discovered i have a hairline crack in it?? Which results in leakage into oil pan?
If in fact the Tank has a hairline line crack, and it was not subject to an over fill, here's an easy fix, rather than replacement.
Just get a Hot Glue Gun and run a bead of hot glue along the crack, and let it dry, cold to the touch.
In my Daughters Pontiac, I had a hole develop in her Radiator over flow Tank, due to vibration and wear against the mounting, along one corner.
I hit the hole with Hot Glue, re-installed the Tank, and it's been holding hot radiator fluid ever since.
I'm sure hot glue will work with a cold fluid Tank, no-problem-o...
