Re: Crossfire Nav Problem
Originally Posted by johnnie265
Does anyone have the jumper wires that come with the Chrysler Nav Unit. These wires connect to the speed sensor or speed signal wire, and back up signal wire. They attach to the radio connector once spliced into these wires. I purchased the factory nav from ebay. Seller did not have the jumper wires that come in the Nav unit from Chrysler. I have a 2008 Crossfire. Chrysler dealer here says they only come with the Nav unit if purchased from Chrysler. I can also be reached at johnnie
2651@verizon.net
The terminals at the end of these wires are available, as they are a standard part. Once connected to the wire they are just pushed into the terminal block that connects to the radio and a barb holds it in place in the block.
These terminals and blocks are used to make custom wiring harnesses' I shall see if I can identify the correct part. You could ask Becker in New Jersey (?) they have the radios and should know the plugs and terminals that fit it.
