Crossfire Nav Problem
Old Aug 5, 2011 | 11:32 PM
johnnie265's Avatar
Default Crossfire Nav Problem
Does anyone have the jumper wires that come with the Chrysler Nav Unit. These wires connect to the speed sensor or speed signal wire, and back up signal wire. They attach to the radio connector once spliced into these wires. I purchased the factory nav from ebay. Seller did not have the jumper wires that come in the Nav unit from Chrysler. I have a 2008 Crossfire. Chrysler dealer here says they only come with the Nav unit if purchased from Chrysler. I can also be reached at johnnie 2651@verizon.net
Old Aug 6, 2011 | 10:22 AM
Default Re: Crossfire Nav Problem
The terminals at the end of these wires are available, as they are a standard part. Once connected to the wire they are just pushed into the terminal block that connects to the radio and a barb holds it in place in the block.
These terminals and blocks are used to make custom wiring harnesses' I shall see if I can identify the correct part. You could ask Becker in New Jersey (?) they have the radios and should know the plugs and terminals that fit it.
Old Aug 6, 2011 | 11:19 AM
johnnie265's Avatar
Thank you so very much. I hope you can identify them for me noone seems to no anything here including Chrysler.
BEATv1
Jul 16, 2015 09:40 AM
ayebb
Jul 9, 2015 07:48 AM
Tommyj
U.K.
Jun 16, 2015 07:21 AM
BEATv1
Jun 12, 2015 05:20 PM
MJPowers
Jun 8, 2015 02:34 AM
