Re: OK, so Crank Position Sensor didn't help...
crankshaft position sensors usually cost around the $45 range. Although I haven't heard of one going bad for awhile, the camshaft sensor can cause this as well. I am sure you have checked for vacuum hoses off, throttle body is tight, no intake hoses off coming from the sc...etc. All these things can cause the problem. Throttle position sensor...etc...
