Old Aug 15, 2011 | 01:22 PM
Buttugly's Avatar
Buttugly
Thumbs up Front Marker light replacement (Headlight cluster)
I posted a HELP asking for ideas on replacing the "FRONT MARKER LIGHT" inside the headlight cluster.
Being the impatient person I am I found an easy way to replace the lights. Here is what I did, I'll add photos later.
I found that you cannot reach the socket by hand and I did not have long enough needle nose pliers. What I do have are lots of tools!!! as it turns out if you have a 10MM open end wrench that is at least 8" long you can reach under the metal bracket on front left and right side headlights with the open end wrench. It fits loosely over the socket, turn it 1/4 turn counter clockwise and it will pop right out. from there you can easily get to the light and replace it. Once you put the new bulb in the socket simply put it back in place and using the same wrench twist it clockwise 1/4 turn and your done.
This took me less that 5 minuets to replace both lights. Hope this helps someone else. These lights are a pain too get to.
