Originally Posted by Kodebuster
With 60k miles, you'll want to peruse the Forum closely for maintenance tips, especially if you don't have those records available to you as part of the purchase...
Yea, I'd check the battery (anything older than 3 years and I replace them BEFORE I run into problems - under $100 at O'Reilly's),
crankshaft position sensor (if you don't replace it, order one and carry it with you - $50 to $65 online),
steering stabilizer (Under $30 online, I put one on at 50,000 miles and the car drives like new - two bolts and it's changed)
and
disable the electric trunk lock (locks the trunk when the top is going up or down, they tend to fail in the locked position - this does not effect the pneumatic lock that operates with the key fob, there is a thread here about it).
That'll get you started!
