Thread: New Rims?
Old Sep 6, 2011 | 05:43 PM
samed11's Avatar
samed11
Default Re: New Rims?
Originally Posted by jmk41
If you want strictly bolt on wheels you options are very very very limited with a little research and some common tools you can make any wheel with 5 X 112 spacing work as long as you stick to 8 or 8.5 inches wide up front and 9 or 9.5 in the rear im not sure how big or small you can go with the wheel height but I have saw 19 and 20 combos. Also are cars have centric hubs but youll find on most wheels with 5 x 112 are setup for centric hubs and will need centric rings for correct fitment. You must also get the correct offset this can be achieved with spacers and correct size lug bolts. If and when you do get wheels be sure that you lug bolts are not to long because in the rear you can run the lugs directly into the ebrake system causing about 1500 bucks in damage!!! When you find wheels you like post them to this thread and i will fix you up I became a pro with this stuff after getting mine to work...
Avarus AV7 Machined w/Anthracite Accent
Will These fit?
