New Rims?
Old Sep 14, 2011 | 07:24 PM
killerkanadian's Avatar
Default Re: New Rims?
Old Sep 14, 2011 | 08:10 PM
Originally Posted by jmk41
Im lost bud... That wheel is a little 2 hairy and cute for my liking! I bet any size bolt would ruin your "wheels".
Take a look at that link you posted...
Buy one long *** bolt with the correct seating (seating explained below) and measure the correct amount sicking out then order the correct sized bolts. I cant give you a number its impossible every wheel is different.
Make sure your able to get the wheel in 8 or 8.5 in the front and 9 or 9.5 in the rear any smaller in the rear will trash your handling and any larger up front will rub in your fender wells and junk!!
Lug bolts come in 2 types of seat tapered, conical, cone seat (those 3 names are different names for the same seat) and ball seat. The bolts used on our stock wheels are ball seat so chances are good you will need to buy lug bolts separate. To my knowledge no wheel is sold with bolts... Even if the ball seated stock bolts are the correct seat for the wheel the chances that the length will match is slim to none in which case you would want to order more bolts anyway because if you cut your stock ones your stock wheel will no longer work.
TSW uses conical seat and as far as I know almost all aftermarket wheels are conical seat. What I did was, I ordered my wheels then ordered the longest conical seated lug bolts so I could cut them to the size I needed. Took about an hour with 3 people helping to cut all the lugs and mount them.
Another idea sadly this just came to me!
When you order your wheels over the phone which you are going to do!!! Never ever trust the online order forms for wheels they are a ***** to return if need be!!! Explain to the sales person that you need specific length lug bolts and if available you would like him or her to get lug bolt thats sick out the mounting side of the wheel a hair under 3/4 i suggest you get a metric measurement in mm so its exact and have them send you the bolts or at least give you the size you will need
**Tips**
1.) If you attempt cutting buy rent or borrow a dye set to clean the threads up before you go running them into your hubs!!!
2.) Run the lugs in and before you really snug them up turn the wheel to make sure your bolts are not hitting the ebrake assembly!!! Im not sure if tightening the bolts down on anything in there will hurt anything or not but I wouldn't test it!
3.) If you cut your bolts have a tube of never-seize handy and cover the bolt with it before you insert it. When you cut the bolt your opening an unprotected bit of bolt and will rust a bit making it an absolute beeotch to get out next time around...
Alright man, thank you for the help. Using your logic and a little of my common sense power i decided to buck up and take the rear wheel off my car. When i unbolted the rear wheel and measured the part of the bolt that stuck out past the wheel, it measured maybe a few mm shorter the bolts i got with my order.
So im stuck with, does 2mm make a difference? is the clearance that close? Well i didn't want to drag the aftermarket wheel out there, with no tire on it because with out a doubt i'd end up contacting the pavement in a way i wish it wouldn't. So i just did a visual check with the wheel off, spun it around to get a good look at what i could see, then pulled the E-brake and spun to see what kind of clearance difference it made. It doesn't look like it will cause a problem, and im going to bet my E-brake system on it because im gonna have a local tire shop swap the tires and wheels out for me, because that's just easier.
Also when you pull the lugs out, you can see the part that are screwed into the rotors and the part that passes into the rotor/ebrake assembly. It just looks like it's covered in a greasy brake dust. So you can kinda tell.
Anyhow, i figured i'd post my experience/logic with the wheels. Also as i said, tire rack sent me bolts that seemed to fit nicely. It might be by chance, or because i matched the wheels up by vehicle and they knew how long bolts i needed.
Old Sep 14, 2011 | 08:13 PM
Also, lol, since my buddy was out of town whom i normally use the shop if, I had to explore the trunk of my XF. I found all those goodies in the back that i never checked for when i bought my car last month. Took me a minute in the dark to figure it all out haha. I was real careful and got a boad to place the jack on becuase i didn't want to scratch up the jack. I wanted to keep it looked unused.
Old Sep 14, 2011 | 08:22 PM
jmk41's Avatar
Well simple take your stock lug and put it in your stock wheel measure the amount sticking out...
Any who as long as the bolts not to long so a few mm shorter wont be an issue but I would want as long as possible on my car that would scare the **** out of me at 150mph lol
Did they send you the correct centric size wheel or were centric spacers included with the order?
3rd edit! lol
After rereading for this for the 6th time i see you said they are longer. Once you get the tires mounted on the wheels take your wheel and your new lugs run them in and with the ebrake off turn your tire and wheel if they are to long you will hear / feel them hit on the inside.
Old Sep 14, 2011 | 08:40 PM
Did they send you the correct centric size wheel or where centric spacers included with the order?
The plastic ring insert? If so, then yes.
Also, since im having them tire swapped and put on the car, i will have to give very very very specific instructions. Kind of wish i had a bench grinder and a rethreader set at the house so i could shave the mm's off.
Edit* And by house, I mean apartment.
Old Sep 14, 2011 | 08:46 PM
jmk41's Avatar
Centric rings are plastic or aluminum so yep thats them be sure those find their way on to the car as well!
Insist that you can watch and supervise otherwise they may end up damaging a 1500 dollar brake system Im sure they wont mind lol Nothing they will be doing could endanger you at all so i cant see why they wouldn't let you stand guard. The shop would be at fault if something was to happen tho and you would get a new brake system...
TerryR
Dec 13, 2019 03:27 PM
Jonacross
20
Jul 17, 2017 11:19 PM
Power Sedan
Sep 20, 2015 09:24 PM
caseydeankopp
Sep 13, 2015 07:25 PM
tom2112
Jul 28, 2015 08:12 AM
