Old Sep 17, 2011 | 05:59 PM
boocher13's Avatar
boocher13
Default Re: Fixing scratched lenses
Mine had a very similar problem just not quite as large,mine where more fogged with some areas that looked cracked like that and the 3m kit took them out nearly 100% you just need to make sure when you use the coarse grit you go over it long enough to get them out.I think you should give the 3m a try .
