Re: Fixing scratched lenses
Yep-listen to James. Those last 3 posts were 100% on the money.
What you see is called "crazing", and is micro cracks in the surface. They are much shallower than they appear. Often caused by application of a solvent, ie alcohol or acetone. Not in our case however.
They will sand out with effort. The 3M kit will work if you follow the directions.
