Old Sep 20, 2011 | 11:09 AM
onehundred80
Default Re: replace crank and cam sensors together?
Originally Posted by Lance1337
The video link of my RCM is:
Crossfire srt-6 srt6 RCM - YouTube
Should I just resolder those joints anyway?
That is not close enough to see any problems.
Solder the joints again, do not use acid cored solder or flux, use resin cored solder for electronic use.
Do a good job or you are wasting your time as just remelting the solder might not do the trick.
Ideally the solder should be removed, the pins cleaned and then re soldered.
