Old Sep 20, 2011 | 10:32 PM
onehundred80
Default Re: P0341 Camshaft postition sensor bad?
Originally Posted by Cedar11
Hello all! I own a 2004 Crossfire at ~51,000 miles. I've had the check engine light on for some time and recently my car had trouble starting. I got the code P0341 and it appears to be the CAMshaft position sensor and I've read descriptions of problems with the camshaft and it sounds identical. When I try to start my car, sometimes it starts fine but sometimes it cranks but doesn't start. It will eventually start, usually the 2nd time but its taken up to 3+ times to start it on a couple occasions. So I believe this confirms it is indeed the CAMshaft sensor.
Now I have a friend who works for Chrsyler and is going to get me the part at a discount but before I dive in I just wanted to know what tools I will need. I found the PDF for replacing this sensor in another thread but it didn't list any tools that would be required. I want to make sure I have all the tools required before I start so I don't need to run to the hardware store during the repair. Thank you very much in advance!
All you'll need is a female Torx socket #E8 and a socket wrench that fits the socket.
