Old Sep 22, 2011 | 11:10 AM
  #347 (permalink)
IBLUBYU's Avatar
IBLUBYU
Default re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by Airscape
I havnt had any issues before but just came out to drive a couple blocks away for a work meeting and can't turn the key. Wheel turns only about an inch either way. Is there some special way to wiggle it (or do I just try to muscle it?) to help get the key to turn. From the sounds of it, this is a recurring issue but mine seems to have gone straight to broke. Any help would be appreciated, I feel like just grabbing the wheel and turning it as hard as possible at this point as it is pissing me off lol.
Geez no ... don't try to muscle the steering wheel. Normally all that is needed is to just rock it back and forth a couple of times while putting light pressure on the key. Before fixing my sticky key, I sometimes removed the key, and made sure to re-insert it all the way into the lock, before attempting to turn it might help. Also try shooting some lube into the lock and on the key. Don't try to force anything...
hope you get this solved. Just my dos centavos .....
