Old Sep 22, 2011 | 02:59 PM
waldig's Avatar
waldig
Default Re: Getting my steering wheel straight
Many look to the front end for alignment. If you have had children you should have the information to know that all in life is not as it should be, ie most things are backwards . The C is no difference when it comes to the steering angle.
You need to have a 4 wheel alignment as the back can thrust you off center and then you have to STEER back on to the path that you want to take. If the rear alignment is off a bit the front has to steer to correct this rear alignment. The front can be all set but the rear toe and CENTERING can cause you all sorts of issues. WOODY
