Old Sep 22, 2011 | 04:02 PM
aschrager's Avatar
aschrager
Default Re: Testing vacuum pump-central locking system
If you look at the diagram you will see that the center yellow line goes to the drivers door. If you can disconnect the other two lines you should be able to see if there is a vacuum or pressure when you select lock or unlock. If you lock the doors and either blow or suck on each line That should lock or unlock the other door and trunk and gas door. It should also show if one of them is leaking. Good luck
