Old Sep 22, 2011 | 06:08 PM
  #44 (permalink)
onehundred80
Default Re: replace crank and cam sensors together?
The AIT sensor is part of the MAF sensor. (Mass Air Flow) It is at the rear of the air cleaner.
If you need to remove the MAF sensor you will find two tamper resistant screws will need to be undone. These are a rare type of Torx screws in as much as they only have five lobes, not the normal six.
You can see that they are a bit chopped up as I managed to use a tamper resistant straight bit screwdriver, the slotted type.
Beaner said he used a regular slotted screwdriver. The screws are a bit tight so be careful you do not stab yourself.
