Old Sep 24, 2011 | 07:54 AM
  #49 (permalink)
oledoc2u
Default Re: replace crank and cam sensors together?
If you need to remove the MAF sensor you will find two tamper resistant screws will need to be undone. These are a rare type of Torx screws in as much as they only have five lobes, not the normal six.
You can see that they are a bit chopped up as I managed to use a tamper resistant straight bit screwdriver, the slotted type.
Beaner said he used a regular slotted screwdriver. The screws are a bit tight so be careful you do not stab yourself.
Security torx screws...Harbor Frieght has the security torx bits...
