Old Sep 26, 2011 | 03:49 PM
Spooky13's Avatar
Spooky13
Default Re: Testing vacuum pump-central locking system
Replaced the CLP/SSM...still no luck. I've also checked both relays under the main fuse box top. The black one is TYCO 002 542 21 19 the yellow one is TYCO A002 542 14 19. Both are working, you can actually feel and hear them click when you depress the lock/unlock on the key transmitter. The last part I guess I can change is the SKREEM then it will be dealership time (which I absolutely despise because for every problem they have fixed they have caused another). If anyone has any other ideas I certainly would appreciate them. Thanks!
