P0341 Camshaft postition sensor bad?
Sep 28, 2011 | 09:24 PM
15
permalink
onehundred80
Apr 2006
25,432
650
Ontario
Re: P0341 Camshaft postition sensor bad?
Quote:
Cedar11
I should have read this post first. After a little research I believe thread chasers will clean up damaged threads where as a tap will remove material? So a thread chaser is what I should be looking for?
No, a tap will only remove material that is in its way, so if there is a distorted thread in the hole it will cut it back to specification. Screwing a quality tap down a perfectly threaded hole will do no harm. I say this but it is possible to buy cheap taps that are oversize, under size or in some cases taps made for a different class of thread with tighter or looser tolerances. A quality tap will be all you need as the different class taps are specials and not to be found at the local store.
It is important to have the tap enter the hole squarely or you will be in a worse shape than you are now.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
