Old Oct 4, 2011 | 05:37 PM
Cedar11's Avatar
Cedar11
Default Re: P0341 Camshaft postition sensor bad?
So a week later I decided to try to screw the bolt it in one more time to make sure the threads were damaged before I went out to buy a tap. I'm not sure what I was doing wrong before but the bolt went in perfectly straight this time around with no problems, this was 2 nights ago. I started the car 2 times and it started just fine, maybe it cranked a split second longer than I was used to but I thought I was nitpicking and was pleased that the problem was fixed. The next morning, it definitely cranked longer than usual but started. I drove it to school and after class it started normally. This morning it once again started normally, however, when I got out of class it nearly didn't start once again! Two times it cranked for 2-3 seconds without starting and it finally started on the 3rd (maybe 4th) time! The check engine light is on once again. Im going to have the error code checked out tomorrow.
