Originally Posted by 32krazy!
as a guess bryan i would check the soldering you did on the paddle shift mod. from what i understand its critical and leaving to much on the underide is just as bad as not soldering it completely. the pics sho a tiny bit sticking thru the holes to solder
Thanks Steve. Chris and I spent a lot of time on the phone about that. Everything tests out correctly. I cant actually drive the car right now so thats why I asked if what I said was normal, that you cant change the gear without moving, if thats the case everything is fine.
