Old Oct 8, 2011 | 09:15 PM
73cuda's Avatar
73cuda
Thumbs up Re: Tempermental Convertible Top
i had the same problem ,took it to the dealership and it checked out to be the top over center switch which is located on the passenger side on the frame of the top. if you run your fingers on the rail you can feel it .dealer wanted 350.00 to fix it but you can manipulate the contacts with your fingers.worked for me and a lot cheaper .good luck
