re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
I am in the middle of drilling the pin, I believe the pin has been drilled plenty deep but the key will still not turn from position 0. I have been using a dremel with multiple attachments and it took about 45 minutes but the pin is drilled deeper than the casing. Could there be another reason why the key will not turn to position 1? the steering wheel is locked to the right but it moves freely to the left.
