Old Oct 13, 2011 | 06:53 PM
  #367 (permalink)
dsdesigns's Avatar
dsdesigns
Default re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Thank you so much!! i have the assembly out and will punch out the spring and pin. The pin i drilled earlier did end up falling out of the casing as i was removing the assembly. I believe i did not have to drill as much as i did and it's too sad that this will never happen again as to give me another chance to perfect this mod.
