Gaelicman and Weebeeste,
I finally got the time and energy to take apart then photo the install. The picture below should take you to my gallery. There are descriptions which accompany each photo. All the wiring was purchased at Advance Auto. I can't remember if I used 14 or 16 gauge wire. I used 16-14 gauge weatherproof butt connectors (part #85240) when I connected the long wire to the headlight socket connector (part #85813). This is the connector for the 9006 bulb, which is what the fog light bulbs are. You also need a set of Torx screwdrivers, specifically T-15, T-20, and T-25. Good Luck!!
