Originally Posted by +fireamx
Anthony, Steve thanks for posting up all those runs on youtube, I got a real kick watchin them.
I do have a couple of questions.
Are both of your cars equally modded?
I see Steve uses the twin CAI vs Anthony's single version. (That was interesting).
What diameter slicks were you using?
I realize Steves car weighs about 70 lbs. more "stock" than the XF, but he does have a smaller battery.
I think it's amazing what "sleepers" these cars are, and what monsters they can be turned into.
i wanted to add a few things about the weight. while my car is a tad bit heavier the shuriken battery drops about 30 lbs off the front . then the 6 piston caliper and 2 piece rotors drop another 30 lbs off the front. remove all the trash out of the back and there goes another 20 lbs. so without getting crazy i dropped close to 80 lbs off the car making about the same weight as the xfire. my pulley is definately much smaller than the 181 and was never designed to be its equal. the ability of the 181 to drop into the 11's with such ease is truely amazing. add the sl55 fuel pump and grip was running rich! retune and he will be even harder to stay up with.
