Racing The place to talk about autocrossing, road and drag racing.
Just another 11 second SRT6.
Old Oct 31, 2011 | 09:30 PM
JHM2K's Avatar
Default Re: Just another 11 second SRT6.
The rest of the guys will have to wait.
I've got some goals next spring that will be interesting to say the least.
Perhaps I can be the first "Limited" in the 12's? (Excluding the V-8 monsters)
Old Oct 31, 2011 | 09:49 PM
grip grip's Avatar
I wish you the best of luck too, John.
Old Oct 31, 2011 | 10:57 PM
Mimi05SRT6's Avatar
Looks like AMX Jim will be bringing his V8 to Orlando on December 4th. I have to make sure I don't sleep at the line and get a jump on him then watch him reel me in from the mirror. Just hope they prep the track ok so we can all hook up.
Old Nov 1, 2011 | 01:40 AM
+fireamx's Avatar
Anthony, Steve thanks for posting up all those runs on youtube, I got a real kick watchin them.
I do have a couple of questions.
Are both of your cars equally modded?
I see Steve uses the twin CAI vs Anthony's single version. (That was interesting).
What diameter slicks were you using?
I realize Steves car weighs about 70 lbs. more "stock" than the XF, but he does have a smaller battery.
I think it's amazing what "sleepers" these cars are, and what monsters they can be turned into.
Old Nov 1, 2011 | 06:49 AM
grip grip's Avatar
I have the 181 and stock differential, whereas Steve has the C3 and Wavetrac. We both run the CM30 and larger heat extractor. I have the SL55 fuel pump and Steve uses the stock pump with front fuel rail x-over.
Mine eat's SLK's and his eats ZO6's.
I think that's about it.
Old Nov 1, 2011 | 09:56 AM
+fireamx's Avatar
Thanks Anthony, just so you know, many of us "NA" owners enjoy vicarious "victories" every time a SRT wins a race.
It makes the uninformed think twice about messing with any Crossfire.
Old Nov 1, 2011 | 10:55 AM
Mimi05SRT6's Avatar
I have the 181 and stock differential, whereas Steve has the C3 and Wavetrac. We both run the CM30 and larger heat extractor. I have the SL55 fuel pump and Steve uses the stock pump with front fuel rail x-over. Mine eat's SLK's and his eats ZO6's. I think that's about it.
Nice. We both are lucky so far with the stock Diff. I've had about 200 runs at the track the last 3 years and am still amazed how well my rear diff is holding up. So I will not be surprised when it does eventually go. All I have is the C3 pulley, CAI, Eurocharged tune, and rear cats/resonator removed. The only cooling I have is the fan mod from the tune and the Code-3 thermostat, which is basically the stock one with 4 holes drilled through it. Takes a long time for the car to warm up during the cooler months though. And of course, the 1 colder Denso Iridium plugs, IK22. Do you remove your car seat when racing? I remove mine and take everything out of the trunk for the track. And I weigh 160 lbs. My drag radials and rims only weigh 5 lbs less than the stock ones.
Old Nov 1, 2011 | 11:32 AM
grip grip's Avatar
I leave the seat in place as well as floor mats and other stuff. However, currently about 7lbs of interior pieces from the hatch have been removed due to a water leak. I won't replace them until I'm certain the leak is fixed.
I also have 1-step colder plugs. I weigh 180lbs, so that helps a little. As for my tires, they are 255/50/16's on lightweight CLK wheels. I doubt each wheel/tire combo weighs more than 25 lbs.
Old Nov 1, 2011 | 11:47 AM
tunaglove's Avatar
Hey Grip, how wide are the rims with those slicks? I have some old Borbet Audi wheels that bolt right up. HMMMM!!!!
Old Nov 1, 2011 | 12:43 PM
grip grip's Avatar
I've received a few requests, so here's the wheel info:
These wheels were a factory option on 98-00 CLK-Class. These wheels are a 129 Type and their MB Part# is 208 401 0002.
The wheels are forged Aluminum and weigh approximately 13lbs each.
Lug Pattern: 5x112mm
Wheel Size: 16x7in
Offset: 37
You will need shorter lug bolts to clear the emergency brake.
Old Nov 1, 2011 | 08:29 PM
32krazy!'s Avatar
i wanted to add a few things about the weight. while my car is a tad bit heavier the shuriken battery drops about 30 lbs off the front . then the 6 piston caliper and 2 piece rotors drop another 30 lbs off the front. remove all the trash out of the back and there goes another 20 lbs. so without getting crazy i dropped close to 80 lbs off the car making about the same weight as the xfire. my pulley is definately much smaller than the 181 and was never designed to be its equal. the ability of the 181 to drop into the 11's with such ease is truely amazing. add the sl55 fuel pump and grip was running rich! retune and he will be even harder to stay up with.
Old Nov 1, 2011 | 10:47 PM
Mimi05SRT6's Avatar
Most definitely.
Goldwing
21
Apr 2, 2025 11:32 PM
MiamiTVR
Jan 30, 2016 02:15 PM
brandoni
Sep 6, 2015 07:35 PM
IsaacF
Aug 13, 2015 07:01 PM
rmcdaniel12
Jul 21, 2015 11:35 PM
